Hi, I recently had someone install a reticulation system in my backyard, connected to a 1hp bore pump. When I turn the irrigation on, this happens (see pictures). Water shoots our for like a second or two.
I did a bit of research and found that this is the highest point in the system (the pipe sticking up in the air), which was probably installed to release air?
However the pvc pipe seems to be just open, there’s no valve or anything and every time I turn the retic on a bit of water shoots out.
Is there supposed to be an air release valve on that pipe? Thanks in advance.
Regards,
