With accurate measurements and a simple formula, you can work out your quantities with confidence and avoid costly guesswork, whether you're pouring a path, setting posts or preparing a shed base.
Measure your area accurately
Start by taking the time to measure your project carefully. The accuracy of these measurements directly affects how reliable your final calculation will be.
Measure the length, width, and depth inside the formwork (the temporary frame that holds the concrete in place) or your holes, then double-check each figure.
Check that everything is square, straight, parallel, plumb and level. Even slight variations can make your calculations incorrect.
While measuring, make sure that you keep all your measurements in the same unit, with metres and centimetres being the easiest to use. This will ensure that your calculations stay simple and consistent.
For smaller jobs around the home, a standard tape measure is usually all you need. For larger areas, a laser distance measurer can make the job quicker and more precise.
To check that the area is level and the depth is consistent, use a spirit level, a laser level, or a tightly pulled string line between stakes. Check out How to choose and use a level for assistance.
How to calculate concrete volume
Most concrete projects come down to two common shapes: rectangular prisms such as slabs, footings and paths, or cylindrical shapes such as post holes or round columns.
For rectangular shapes, use the calculation Length × Width × Depth = Volume.
For example, a slab that is 3 m long, 2 m wide, and 0.1 m deep would be calculated as: 3 x 2 x 0.1 = 0.6 cubic metres.
For cylindrical shapes, the calculations are a little more complex. You need to use π (pi) and radius. Pi is a number used whenever you measure something round. It’s value is approximately 3.14.
Radius is half the diameter of a circle, the distance from one side to another, passing through the centre. When we calculate radius, the number is squared, which means a number multiplied by itself.
For cylindrical shapes, use the calculation π (pi) x Radius² x Depth = Volume.
As an example, if a post hole is 0.3 m wide, the radius is 0.15 m. At a depth of 0.6m, the calculation becomes: 3.14 x 0.15 x 0.15 x 0.6 = 0.042 cubic metres.
If you are pouring several holes or columns, calculate the volume of one and multiply it by the total number required.
Remember to subtract the volume of anything that will displace concrete, such as posts or pipes, so you do not over-order.
If your project is an irregular shape, break it into smaller sections, calculate each section separately, and add them together. Taking it step by step usually makes even awkward layouts manageable.
How to convert concrete volume to the number of bags needed
Concrete is measured in cubic metres, but for a small project you would typically purchase 20kg bags of premixed concrete. To estimate how many bags you need, convert your total volume using an average yield guide.
As a general rule, 1 cubic metre requires about 110 bags of 20 kg concrete. So you need to multiply your total cubic metres by 110 to estimate the number of bags required. For example, if your calculated volume is 0.42 cubic metres: 0.42 x 110 = 46.2. Since you cannot buy a fraction of a bag, round up to 47 bags. It is always better to have a little spare than run out with the job unfinished.
Always check the coverage information on the packaging, as yields can vary slightly between brands.
Please note that for larger pours such as driveways or house extensions, ordering ready mixed concrete by the cubic metre is often more practical and cost effective than mixing by hand. In that case, accurate measurements are even more important.
Allow for waste and extra concrete
Even with careful measuring and calculations, conditions on site are rarely perfect. Ground can be uneven, formwork can shift slightly, and small amounts are often lost during mixing and pouring.
To reduce the risk of running short, it is wise to add 5 or 10 percent to your calculated total. For example, if you needed 0.6 cubic metres of concrete, it would be wise to allow for 0.66. This small allowance gives you breathing room and helps keep the job moving smoothly. Having a little extra at the end is much easier to manage than trying to mix more while the first batch is already setting.
If you are buying bagged concrete, you can return unopened bags that remain in good condition. Simply ensure you store spare bags somewhere dry, raised off the ground, and protected from moisture.
More help for your concrete project
Concrete work rewards preparation. Measuring accurately and allowing a safety margin cuts waste, avoids surprises and helps ensure a more successful result.
For more advice, check out our guide How to pour a concrete slab by experienced community member @tom_builds, and feel free to hit the Ask a question button if you need personal assistance.
