Hey guys,
Unfortunately due to some poor choices by whoever originally built our house, I have to install a nib wall on either side of a new double shower. I also need to raise the shower floor which means installing a hob. The walls of the house are double brick, and it is a second story concrete slab floor.
The nib walls will come out approx 550 from the external walls, will be approx 1000 in height, and will only be about 90-100 thick. They will have glass panels above them and one will have a large shower door hinged off it. I can’t really go any thicker as it will encroach too much on the usable shower space due to having to build a ledge against the backwall to hide a toilet waste pipe that runs along the wall.
My original plan was to build the hob from a single course of bricks, then bolt a stud frame on top with 90x45 LVL and then sheet it and tile it. But a tiler who quoted my job said every time he has seen a timber stud nib wall done, it has never worked too well and slight movement of the nib wall causes issues.
So what is the best option that wont cost through the roof here? Build the hob and nib walls entirely from brick? Surely that may still suffer from the same movement issues?
Build the hob and nib walls from 90mm besser blocks tied into the external walls and the concrete slab floor with vertical and horizontal reo bars, then core fill it? Surely that would be solid as hell, sounds pricey.
Any ideas much appreciated. I also added an AI mock up I created to show the look we are going for. Our shower wont be set back that far though, it will be inline with the door opening to the left, I just couldn’t get AI to replicate that is all.
