I have regular boring builders skiting that is bullnose about 10mm thick and 650mm high. I want to replace it and looked at skirting cladding in Australia but the styles are really limited and only about 2 places I can find that does it. I am trying to avoid having to take all the existing off!
I like this one and wondered because it is thicker, could it be routed out somehow and then used to clad. Would that be a home job or is there a way to get the routing done somewhere? Is the cost likely to out way the effort/ possible wall damage saving?https://www.bunnings.com.au/138-x-18mm-2-7m-white-primed-fj-step-pine-moulding_p0489335
Would love if Bunnings could have a product like this available. There is a company in UK that has this and has loads of options but it doesn’t seem a thing really here?
Any advice on the best/easiest way and if using regular skirting and turning it into cladding is even a viable consideration.
Cheers
