Help, bad tap seal leaked from shower tap through into hallway skirting board behind shower. No idea how long it was leaking. Removed wet skirting board from hallway wall when i found small amount of water on hallway floor directing behind shower. Tore a bit of paint off the wall which revealed mild mold on wall above skirting board in hallway. Silicone has been replaced in shower and no more leaks. Been pressure tested for other leaks and all clear. Do i need to open the wall to remove mould professionally? No mould had come through paint in hallway or through tiles in shower. House built 1993.
Do i need to open wall to check condition of possible water damage to base plate?
