Hi everyone,
I’m looking for some advice regarding my ducted AC return air grille (Smartgrille type).
I’ve attached photos of the grille and measurements. The size is approximately 495 mm x 365 mm, which doesn’t seem to match standard sizes I can find at Bunnings.
I have a few questions:
- What size filter should I be looking for (or closest standard size)?
- Does Bunnings stock anything suitable, or provide cut-to-size filter sheet with a frame?
- Do I need to buy the filter with a frame, or is just the filter material enough for this type of grille?
Also, I wanted to check — do I actually need a filter here?
I contacted my builder (Henley), and they mentioned a filter is not required, which is why it wasn’t installed. However, I’ve seen other Henley homes (including a friend’s) where a filter is installed in the same type of grille.
So I’m a bit confused:
- Is a filter optional or recommended?
- Are there pros/cons of running without one?
Any advice or product recommendations would be really appreciated.
Thanks in advance!
