As per title. Gap between wall and concrete(?) Footpath ranges from 0.8mm to 1.2mm
Ta
Hello @JackW97
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about filling the gap between your wall and path.
I propose using https://www.bunnings.com.au/moroday-6mm-x-5m-white-gap-filler-rod_p4061882 and pushing it into the gap at least 5mm deep. For the larger gap, I suggest using the https://www.bunnings.com.au/moroday-15mm-x-5m-white-gap-filler-rod_p4061877 . Once the gap filler is in place, I suggest using https://www.bunnings.com.au/sika-300ml-concrete-grey-sikaflex-11fc-purform_p0628962 to seal the gap between the wall and the path.
Thank you Eric.
Besides a caulk gun, would you recommend me any other equipment for this task?
I suggest using some disposable gloves just in case you need to push or adjust the sealer.
Hi @JackW97,
I thought I'd add this helpful step-by-step guide on How to fill a gap in concrete.
Let us know if you need further assistance.
