Hello,
I am trying to figure out the best way to create a seamless external fibre cement sheet corner joint using 6mm exterior cladding sheets to try and achieve an exterior rendered look without rendering. Would using Siniat 30 x 2400mm 90° External Angle Plaster Trim and a fibre cement joint compound work?
