Hi
I have a small brick walled garden bed. I didn't build it and I didn't render it but it seems to have been rendered in the past with a very rough textured finish and then painted. Some of the mortar between the bricks has broken away.
I thought about just repainting it but I think it needs some sort of patching up and the brick holes filled before I do that.
I am therefore thinking of either bagging it with a render mix or using a medium textured paint. I was thinking with either option that I would apply it with a lambswool mitt to keep the rough and ready look.
I have removed loose render and the surface is not smooth. The wall won't be any sort of feature wall so I don't need to make it look pretty. Just better than how it is.
What I want to know is:
- Can I bag render over the existing render? If yes, what pre-mix mortar product should I use? Do I need to prep the surface (either the existing painted render or the bare brick)?
- Can the render be used to plug the gaps between the bricks where the mortar has come away?
- If I use a textured paint instead, can I apply it straight to the existing render or does it need surface prep?
I don't want to spend a lot of money on this because it is a small amount of wall which almost no one sees!
