I need to replace/patch the mortar gaps on either side of this letterbox. The frames are solidly bedded in, so it's just patching for cosmetics and weather protection.
My plan is to clean out all the loose debris, then cut some strips of plywood the same width and height as the gaps and wedge them in from the inside, giving a surface to bond onto. Then take either Mortafil or No More Gaps Bricks & Mortar and fill in the surface from the outside.
Does this sound like a good approach? Or is there a better method?
