Hi guys,
Out of many project, this one is also in my list. I thought I start prepraring my thougths and also advise and recommendations from experts.
Here is the details:
Following are the images of the living room. This room is being used as my office, has one set of sofa, kid's toys, small pantry and one cupboard as you can see in these images.
My plans are:
1.) Hybrid Flooring
2.) Having corner Pantry
3.) Sliding door on both openings
Questions are :
- ) I had done one project (https://www.workshop.bunnings.com.au/discussion/288265/walk-in-wardrobe-renovation#latest) before where I had done hybrid flooring myself. It was done for a smaller area. This area I am trying to do is much larger area. I sometimes feel some clearence or as if there is gap between the hybrid flooring and the actual floor itself. or, it could just be my feeling or sense, I cannot say. Before I had not used any underlay, could this be because of that. The previous project image are in above link. If the underlay plays vital role in stability and acoustic of the flooring, then I might as well use that in this project.
2.) Where I have green colored for the Corner pantry- there is a big window/ door. I am not getting my head around, if I put the corner pantry, how would it look with the clear screen at the back of the pantry. i was thinking if I could hide or cover the clear screen half way using something, that will create as a wall or cover, if you know what I mean. Please suggest here. Following is one from Kaboodle and i may add one extra one each sides.
3.) I am also planning to setup one small area 1600 x 1600 for kids play, just under the aircon. Initially I had a plan to have a partition like this, and seperate, Area1 : Kitchen panty + Small space ( approx. 600-1000mm) and Area2: Kids play area + sofa bed + plants at the corner. This is along the longest side of the room.
Any recommendation around this?
4.) Sliding door - regarding this, I had already one post from sometime ago. I will go back to same post and may continue my queries there. https://www.workshop.bunnings.com.au/discussion/257068/how-to-add-barn-door-for-privacy-in-second-living-area?tab=all#latest
