Have I messed this up?
I failed to do the proper research on how to do the cut outs for light switches for the VJ panelling. Unfortunately it wasn't until after I did the cutting that I made this realisation. When doing the research it seemed that everyone's advice is to get an electrician to remove before and make a smaller hole, pull wires through and then reinstall. Now having already done the cut will it work if I get an electrician out to put in a mounting plate so the switch is brought forward and the cover can be placed back on. Once this is done install panels and fill in gaps. Or any other suggestions to avoid cutting another panel. Thanks
