HI.
While making a roof with corrugated iron, there will be an overlap of two sheets. My question is: Could condensation be formed in the overlap. The roof exist of Sips (metal - foam - metal) with 40mm purlins on top, insulation on top of the Sips between the purlins and corrugated iron on top of the purlins.
A sheet overlap ends at my chimney outlet and I have leakage on that spot. Where is the water coming from.
I hosed the whole area and no leakage.
The angle of the roof is smaller than 5 degrees.
Maybe there is someone with the same problem?
lebobo
