I own a townhouse with the storm water run off that ends half way down the side of my house. I want to add a step over the existing end that goes between the wall and fence to make it a lot safer to walk around the side of the house. I'm planning to extend the current ends with pcv pipe extenders, build a frame with wood, and fill with concrete. Also, I'll add some road base and soil up from the step to cover the exposed pipe, meaning the step will be a fair bit higher then the existing dirt level. My question is how much/if rebar is necessary, and how to best prepare the existing concrete, and anything else I haven't thought of. Ideally I'd like to also add pavers on the concrete to match the nearby patio. Any thoughts will be greatly appreciated as it's my first time using concrete!
