Hi everyone,
Looking for guidance on how to convert the screw on benchtop dishwasher to sink tap attachment into a more convenient snap on adapter for easier use. Appreciate all your help with ideas and suggestions. Thank you.
Hello @SG-
I suggest changing your tap adapter into the https://www.bunnings.com.au/pope-indoor-tap-adaptor_p3111029 I recommend adding the https://www.bunnings.com.au/holman-12mm-double-ended-hose-connector_p3130593 and attaching the https://www.bunnings.com.au/holman-12mm-brass-sprinkler-adapter_p3110589 to the washing machine hose. This will give you the quick disconnect option and get the dishwashing machine hose out of the way.
I also suggest having a quick look at this discussion - Benchtop dishwasher quick release connection by @jenenev
Thank you Eric. Will try that.
