Hi, can anybody tell me the DAVCO/Bunnings equivalent of MAPEI ECOprim T+ primer, and S2 T Flex adhesive?
Thanks, Wayne
Hi @waynehazell,
Without knowing the context, you are using them in, I would be hesitant to say a specific product as there are differences between products and generally when a product is specified, it is done so for a reason.
If you could advise the context which you are using them, we could certainly reach out to Davco for their recommendations.
Generally speaking, https://www.bunnings.com.au/davco-5l-ultraprime-primer_p6658124?srsltid=AfmBOoo3IOnftyEquT_Ip0HHFMBYcvK7hv-Kyr7iBWI2Yx995_UlIoc1 can be used over porous substrates such as rough finished concrete or cement based self-levelling compounds, whereas you would use https://www.bunnings.com.au/davco-5l-primex-surface-primer_p6650246 over non-porous substrates such as compressed fibre cement or trowel finished concrete.
In terms of adhesive, https://www.bunnings.com.au/davco-20kg-smp-evo-tile-adhesive_p6650266 is similar, but again we would need to know the context which it is being used to be confident it will apply to your situation.
Let me know what you think.
