I need to replace the toilet pan cone. I understand there is 40mm and 50mm pan cone. How do I know what size I should get for my toilet?
Thank you.
Hello @qnmk
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your pan cone size.
Please note that plumbing work needs to be completed by a licensed professional for safety and compliance.
Generally speaking, the majority of modern toilets use the 50mm sized pan cone. These would be the https://www.bunnings.com.au/deks-50mm-black-dekfit-rubber-pan-cone_p0035051 and the https://www.bunnings.com.au/dekfit-50mm-white-rubber-pan-cone_p0035052 . Both do the same job, and the only difference is the colour. However, the https://www.bunnings.com.au/deks-40mm-black-rubber-pan-flush-cone_p0035049 is used for much older toilet systems.
A quick way to tell which pipe size you have is to place a tape measure across the front of the pipe and keep a steady hand so that you can measure accurately.
