Can anyone help with suggesting a mini cistern tap that uses a 10mm tap valve?
I was able to fix a leak on one of my under vanity cistern taps by replacing the tap valves and o ring but can’t take the nut off for the other one so I am thinking about replacing the whole tap. I’ve tried wd40 and a hair dryer.
The existing fittings looks very similar to the brass head 15mm taps but unsure if the connections are the same given the old one uses a 10mm tap valve. I’d love to change to a more standard sizing if I’m able.
https://www.bunnings.com.au/brasshards-mini-cistern-tap-15mm-chrome-lead-free_p0571971
Any suggestions or tips would be appreciated.
