Hi, I have zero plumbing experience and my hot water tank tap is super old, rusty and leaking. I thought I could easily replace it but have encountered a couple of problems - the main one being that the turn handle is so close to the tank, it’s preventing me from unscrewing the whole fixture (handle and valve) from the pipe. I have some ideas of how I could remove it (ie using a grinder) but in terms of fitting a replacement, Im wondering could I install the new turn handle and valve separately as they seem to come as a single piece of kit? If I could separate the new valve and handle from one another then it would allow me to screw in the valve first and then I could just screw in the new turn handle into the valve?
Other (minor) problem is I don’t really know what size I need - I did buy a 15mm set earlier today but it looks to be way too small compared to the existing one? Any help/advice would be great! Photo attached:
Thank you!
