I have three wide spaces to bridge with Marquee clear cafe blinds. I is approximately 5m, the other approximately 3.6 m.
The problem is to select the correct width of joiners and extenders and end pieces (the bits that slide into the wall holdings. I cannot find any guidance to work out just which bits to use to cover a certain distance. I want to use the widest blinds possible. For example the 3.6m gap could be bridged by 1 3m wide blind leaving ~ 300mm to bridge to the post on each side. So if you use 2 x 1.8m blinds it costs more and one you allow for the joiner in the middle - what is the actual space bridged?
I end up with questions like: Does the stated width of a blind include the zips? When you join two blinds together how do you calculate the final width - arithmetic or do you have to make allowance for the zips.
There has to be an equation for all of this but so far all I can find are instructions for hanging just one blind!
I would appreciate links or just guidance on how to make the measurements.
The mechanics of hanging are not an issue - have done that before.
Look forward to responses!
