I have these plants but need advice as there going brown.
Hi @ellhawthorn,
It looks like there are a couple of different symptoms going on, but at this stage, it’s hard to pin down a single cause without a bit more detail.
Browning can come from both overwatering and underwatering. For example, general leaf browning can point to too much water, while crispy edges can sometimes suggest the plant is drying out or getting too much sun. The tricky part is that these issues can look very similar, which often leads to a bit of a cycle of wondering whether you’re watering too much or not enough. The goal is to keep the soil evenly moist and only water when it starts to dry out. Constantly soggy soil can be just as harmful (if not worse) than letting it dry too much.
If you can share a bit more about how long this has been happening, how often you’re watering, where the plants are positioned, how much sunlight they get, and whether you’re feeding them (and with what), it’ll help narrow things down and give a more accurate diagnosis. Here's a helpful guide: How to diagnose a sick plant.
