just want to see how i can mount my dryer if there is no studs in the wall where it needs to be mounted.
There’s stud further apart from where the bracket needs to go
Hello @shaniya
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your dryer.
This is a popular question that has been discussed before. I suggest having a quick look at these discussions - Mounting a dryer without a convenient stud by @Jackalman and How to mount dryer with no studs? by @bect73. Generally speaking, the mounting technique involves putting a timber piece such as a 90x45 or similar across two studs. You then screw the dryer bracket onto the timber piece and hang the dryer from there. There are some good examples in the discussion on what screws to use for the stud wall.
