I am in the early stages of a kitchen design for a new build and hoping to install a custom side-by-side appliance bank at approximately benchtop height for accessibility and would love some feedback on my configuration plan.
Instead of a single tall tower, I want to install two 600mm Kaboodle Oven Cabinets side-by-side on top of two 600mm base/drawer units. This will house:
Cabinet 1: A standard conventional wall oven.
Cabinet 2: A Panasonic 34L 4-in-1 Convection Microwave using the NN-TK81KCSCP Trim Kit.
The Panasonic manual specifies a minimum depth of 533mm and requires a full-height rear ventilation path for the air fry/convection functions. Since the Kaboodle oven cabinets are 540mm deep (including the door) and 688mm high, I have a few specific plan details I’d like to run by anyone with professional experience:
For ventilation I plan to pull the entire two-cabinet bank forward by about 30–40mm so the microwave ducting doesn't hit the wall. I’ll then use Tall Pantry End Panels to hide the "chimney" gap against the wall from the sides.
To fill the vertical gap above the microwave trim kit, I’m planning to use a 600mm 1-Drawer Panel or other filler panel. I will have a space cut within this panel to mount a recessed aluminium ventilation grill.
I’ll be using the Heat Deflector Strips from the Kaboodle Oven Tower Pack on both cabinets to protect the finish.
My Questions:
Has anyone else used the standard Kaboodle oven cabinet for a large convection microwave like this?
Does this plan sound safe and achievable?
Is a 30–40mm rear chimney gap sufficient for the convection heat, including a ventilation grill recessed within the top filler panel?
Are there any concerns with the structural weight of the two cabinets sitting "mid-height" on base units?
Any advice and feedback from the experts or anyone who has done a similar benchtop level convection/microwave oven cabinet using Kaboodle would be greatly appreciated.
