Hi, my garage has a concrete slab floor and besser block wall. There are some large cracks (20 - 40mm) between the concrete slab and the wall. See photos. How can I fill this in and seal it.
I was thinking either use grout or expanding foam until 10mm below the surface then some flexible concrete sealant (Sikaflex etc) to the surface. Or maybe a foam backer rod and then sealant on top of that. Ideally I would just grout to the surface but it if moves again this will obviously crack again.
I realise this doesn't fix the structural issues but we will replace the shed in the next 3-5 years anyway.
There are also some smaller cracks between the besser blocks in the vertcal walls and I plan to use expanding foam or flexible sealant on these.
Thanks
Kane.
