We have a 200 year old terrace. Door way is rendered over brick anf concrete. Very badly damaged. Tryingbto work out how to restore. Please help!
Hello @miraperry
I suggest having a quick look at this guide - How to repair a rendered wall by @Nailbag. It's an excellent guide that will give you the necessary steps to fix your chipped wall corner. The general steps are to clean the surface very well before you apply the filler. You can mask sections of your wall so that filler will not spread too far on the surface. I recommend using https://www.bunnings.com.au/polyfilla-500g-exterior-brick-and-render-masonry_p1210565? to cover the chipped sections on your wall.
Thankyou
Kind regards
Mira
