Hi everyone!
I am wanting to build a catio outside for my 2 cats (4-6kg), however it is likely to be relatively temporary, 2-3 years maybe, as I don't own my house so I am not wanting to spend a fortune and don't really know where to start with building materials!
I will attach a photo of the space I am working with and an inspo pic to give you a rough idea of what I'm planning to do, however I am hoping to make the catio a bit longer ~4x1.2m and about 1.8-2m tall.
I was planning to do this with 90x45mm timber, but this will be far too expensive unfortunately. Is there a cheaper alternative that will still provide enough support for my cats? Would also appreciate a suggestion for what screws to use for this, as well as what I could use to create some perches/shelves for them to climb and rest on.
I will also need to build a tunnel that leads to the cat flap which will rest on the ground. What size wood and screws will be best for this?
Some other random questions:
Is it necessary to seal/paint the wood or can I leave as is? If it is necessary, is it best to do this before or after assembling?
Is it necessary to fix the structure to the wall or is there a more temporary solution?
Is it possible to do this project in a cost effective but safe way? Or is it best to come up with an alternative plan?
Thank you so much in advance for all your help!!
