I would like to mount the Gardena 20m Hose Reel Set (https://www.bunnings.com.au/gardena-20m-hose-reel-set_p0298515) to the back of my house.
The external walls have some cladding on them (not sure of the thickness) and the house has a steel frame, so I would want it to be mounted into the steel studs for better support.
My main question is whether the included mounting screws would be enough for this or if I should get longer and stronger screws, in which case, which screws would you recommend? I have attached a photo of the corner I would like to mount it on, just above the tap.
Also I'm happy for suggestions for a cover that would protect it from UV rays for longevity as Gardena don't appear to sell a designated cover for it.
Cheers!
