I'm building a set of steps attached to a retaining wall as per the attached image. I'm using steel H / C channels to secure the retaining walls which are marked in yellow. I'm not sure what to use for the areas marked in red through? Should I use something like a star picket behind the step corners to hold them in place? What screws / brackets should I use to assemble the steps and secure them to the retaining wall?
I eventually want to fill my steps and install pavers (likely not mortared in just with sand)
