Painted my daughter's bedroom with a stencil for a wallpaper look.
All in one Primer, Sealer and Undercoat
Dulux Natural White Low Sheen
Dulux Low Sheen paint colour Lilac (unsure of colour name because I picked this up from the mistint clearance table)
Dulux Bee Hall Low Sheen
180 grit sand paper
Cutting in brush
Frog Tape
230mm 10mm Nap Roller
Sand walls down with 180 grit sandpaper, then clean with Sugar Soap.
- Step 2:
Apply primer.
- Step 3:
Apply 2 coats of Dulux Natural White.
- Step 4:
Using a laser level makes this easier to line up, but if you don't have one just measure out using a measuring tape. I started in 5mm from the left and measured out every 10cm, making sure the tape was applied in sequence.
- Step 5:
I painted the purple stripes first, applying 2 coats.
- Step 6:
I then applied the stencil with a brush, applying only 1 coat.
When this was dry, I then applied Dulux Bee Hall to the flowers for a subtle pop of colour for detail.
- Step 7:
I then finished up the room with the Lilac colour framing the window, and Natural White for the rest of the room
