Hi All,
I'm looking for some advice around replacing an old rotting wooden door frame with a metal one on the side of a garage. Specifically: I'm after a
few product recommendations as none of the door frames on Bunnings website seem to provide minimum opening size
Its in a position that's exposed to the elements with no cover and the previous wooden one hasn't lasted as long as it should.
The opening is between two brick columns that measure about 230mm deep, and has a rough opening size of 2080 x 880mm (I've allowed about 5mm tolerance on the width and 20mm on the height).
Due to the position of the door it needs to swing inwards into the garage. When standing on the outside of the garage the door handle is on the left, and the hinges are on the right.
There's currently no sill however as water comes in beneath the door I'd like some weatherproofing if possible. Unfortunately the garage roof is only 2100mm high so I'm somewhat limited with overall height.
I already have a Parkwood 2040 x 820 door to install so I'm just after the frame.
Thanks,
LV
