Hi everyone,
I’m looking to build a simple dome structure over my raised garden bed using PVC pipes, similar to this video:
https://www.facebook.com/BlackwoodHomeHardware/videos/1553482165927491/
The goal is to protect young fruit trees from frost in winter and heatwaves in summer.
I currently have two types of garden beds:
- Type 1: Round bed (diameter ~97 cm)
- Type 2: Rectangular bed (W31 × L183 × H74 cm)
I’d really appreciate your advice on a few things:
- Pipe size: 20mm vs 25mm
Would either of these be suitable for bending into a dome shape?
Holman 25mm x 3m Class 12 PVC Pressure Pipes https://www.bunnings.com.au/holman-25mm-x-3m-class-12-pvc-pressure-pipes_p4770099
Holman 20mm x 3m Class 12 PVC Pressure Pipes https://www.bunnings.com.au/holman-20mm-x-3m-class-12-pvc-pressure-pipes_p4750039
I’m aiming for something that bends easily but is still stable.
2. Connecting the top of the dome:
In the video, they mentioned using a cross connector to hold the two pipes together at the top.
I’m not quite sure what this piece looks like. Could someone point me in the right direction?
3. Securing the pipes into the soil:
I’m thinking of using reinforcing bars like these:
Jack 12 x 300mm Reinforcing Bar https://www.bunnings.com.au/jack-12-x-300mm-reinforcing-bar-5-pack_p0231508
Jack 12 x 600mm Reinforcing Bar https://www.bunnings.com.au/jack-12-x-600mm-reinforcing-bar-5-pack_p0231504
Would 300mm be sufficient, or is 600mm a better option for stability?
4. Transporting the pipes:
For 3m (or even 6m) pipes - How do people usually transport these home?
Is it possible to bend them into a small SUV?
5. Alternative approach (modular frame)
I’m also considering building a square/rectangular frame using shorter pipes and connectors (based on Holman’s garden cover guide):
https://www.holmanindustries.com.au/garden-cover-guide/
With the modular frame, I will use coupling, 3 way and 4 way corner connectors to connect a bunch of 1m pipes together. My concern is how stable the structure will be. My raised bed is already 70cm above the ground.
Any suggestions, improvements, or alternative ideas would be greatly appreciated.
Thanks in advance for your help! 🌱
