Hi Bunnings team,
I’ve started insulating my subfloor, and wasn’t sure if I should use earthwool subfloor insulation, or if I could get away with using earthwool ceiling insulation? (mainly as the subfloor earthwool insulation at Bunnings only has an R value of 2.5, and don’t want to use any polyester insulation as that would be silly in the case of a fire).
Due to the house structure, there is a depth of approx 450mm where I could stuff in plenty of insulation. Therefore, I was wondering if I could use earthwool ceiling insulation of R5 or 6?, which is much thicker. As this is earthwool, I assume there would be no moisture issues? Or am I mistaken, as the thickness could increase the risk of moisture being trapped?
What is the difference between earthwool ceiling and subfloor anyway? Can’t be much difference, or is there?
Should I also cover the mesh with the aluminium insulation foil, or does that increase the risk of trapping moisture even more (even if the foil is breathable)
Many questions I know! :) Thank you for your help
