How can I DIY rendering Hebel panels for extended walls including covering gap where Hebel propanel meets existing Bricks.
Hello @ELI5
If you are referring to the Hebel Power Panel, Rendering it so it blends neatly with an existing brick wall is achievable as a DIY project, but it needs to be approached as a system, not just a standard render job. Hebel PowerPanel is designed to work with specific coatings and jointing methods, so while the general idea of priming, base coating, reinforcing, and finishing is still correct, the materials and detailing should follow a Hebel-compatible or manufacturer-approved system rather than a mix of generic products. You would begin by ensuring the PowerPanel surface is clean and dry, then apply a primer or sealer suited to AAC to control suction. From there, a polymer-modified base coat render is applied, and this is where an alkali-resistant fibreglass mesh is embedded across the surface, not just in isolated areas, as part of the crack control system rather than an optional reinforcement.
Where the Hebel Power Panel meets the existing brickwork is the most critical area. These two materials move differently, so instead of trying to hide the junction completely with rigid render, it should be treated as a movement joint. In practice, this means maintaining a small gap, inserting a backing rod if required, and using a high-quality flexible external sealant to accommodate movement. The render system is then brought up to the joint and often reinforced with mesh near the transition, but not in a way that locks both substrates together rigidly. This is a subtle but important distinction, as fully bridging the joint without allowing for movement can lead to cracking over time. Some Hebel systems also specify joint sealants or proprietary compounds to ensure compatibility and long-term performance.
Once the reinforced base coat has cured properly, a compatible finishing render or texture coat is applied across both the Hebel and brick surfaces to create a consistent look, followed by a suitable exterior paint system for weather protection. The end result can look seamless, but it relies heavily on correct preparation, product compatibility, and especially joint detailing.
While the overall process sounds straightforward, Hebel Power Panel installations are less forgiving than standard rendering because the performance depends on following a coordinated system. Small mistakes, particularly at joints or in product selection and application can show up later as cracking or visible lines. For a smaller, less visible area, a careful, detailed DIY approach can work if you stick closely to a proven system, but for larger walls, façade work, or anything tying into existing brickwork, it is often worth having a professional renderer who is experienced with Hebel. Their familiarity with movement joints and system requirements usually makes a noticeable difference in both durability and finish. Plus, the work is covered with the tradies guarantee.
Hi @ELI5,
Just as a follow-up to Eric's helpful application advice above, https://www.bunnings.com.au/rockcote-15l-polymer-render-grey_p0760267 would be the appropriate render for the job. Rockcote also does the required reinforcement mesh. They are available through our Special Orders team in-store. The flexible sealant for joints to other substrates is Sikaflex 11FC.
