Hello
During pre-inspection over a year ago I was told that there was a slight leak in the wall.
Also, a contractor's quote showed 99% moisture on the floor (the same spot where water ended up from my recent red dye leak test - see photos).
I "fixed" the shower screen with flashing tape.
For the leak to the wall, at the moment i'm taping plastic sheeting across the wall just under the taps, as I'm guessing the leak to the wall is through the grout. So I'm basically just covering up the grout.
I'm wondering if completely waterproof wall panels placed over the tiles would work for the leak going to the wall as a more permanent fix.
I don't have the cash to spare at the moment for a major reno. But I don't want to make things worse either.
Any suggestions re the wall panels, and if so, can you recommend a particular type?
And any suggestions for the shower screen leak? The flashing seems to be working at the moment.
Thank you for your patience guys.
