Had a concrete job done for a back yard step and patio, however not happy with workmanship…
- Uneven finish to fence cladding—is there a way I can caulk this? The trenches in the fence cladding makes this tricky
- Wonky hand groove lines—I should be able grind this with an angle grinder?
- Concrete step poured up to the house frame (timber + aluminium)—this is a bigger issue that would rot/corrode the frames, which I may need to get the concreter to come back to cut back the slab and rectify OR get another concreter to rebuild/fix up
- Front of concrete step not finished properly, resulting in significant amount of visible air bubbles—I might be able to grind this back and acid treat to smooth surface…
3 questions for the community:
A) is it reasonable to ask the concreter to rectify all four above?
B) What leverage do I have to compel him to rectify?
C) Can I fix the uneven pour against the fence cladding with external sealant? How might I achieve a clean finish?
Thanks all!
