I am nearly finished framing up a ledge in my new shower but just have a quick question regarding a window sill.
I want the ledge to finish flush with the rendered brick window sill as both the sill and the ledge will be tiled.
The frame will be sheeted in 6mm villaboard. So do I finish the frame 6mm lower than the sill to allow for the thickness of the villaboard? Or do I finish it about 15mm lower than the sill to allow for villaboard and render?
I have read that sometimes you can directly tile onto villaboard, though not sure it just seems a bit dodgy.
Cheers,
