I wanted to highlight my tv area in the living room with acoustic panels and some bias lighting around the TV to soften the look.
Acoustic Panels
Bias lighting
Circular saw
Jigsaw
Adhesive
First i had to remove the TV and speakers to get a blank wall.
I then found centre of the TV mount and then extended a vertical line up the wall so I could align the panels correctly.
The first panel was the second from left. This was first as it was aligned to the the level vertical line and guaranteed the remaining 3 panels were square.
I cut the panels from top of the skirting board to the cornice and then used liquid nails and flat head screws.
I then continued mounting the remaining 3 boards cutting around the cable outlets and powerpoints etc
