I have a cracked outdoor tile on my townhouse balcony and I can't find a similar replacement tile.
It has cracked in three places and the center section has some movement when I press on it.
Is there a way to repair the tile?
- Either by injecting something into the crack and using some touch-up paint?
- Or pulling up the tile and then bonding the cracked pieces?
I assume given there is some movement beneath the cracked portion, the tile really needs to be pulled up, but that will also like crack the tile more?
I will be getting the grouting repaired professionally.
Note: On the balcony there is a black waterproofing layer that the tile is laid over.
The original tile name:
Beaumont Tiles – Touchstone Nero Porcelain Rectified Textured – 300x60
