Just had to concrete under this waste trap and pipe and wondering whether this is enough fall for the waste pipe?
Pipe run is approx 600mm with a 90 degree elbow on the other side of the wall.
Cheers.
Hi @bigkid,
Please note that plumbing work needs to be completed by a licensed professional for safety and compliance.
Setting and installing waste pipes, including getting the correct fall, is part of regulated plumbing work and needs to be carried out by a licensed plumber. They’ll ensure it meets the required standards for drainage, prevents blockages, and complies with local codes.
Unfortunately, I’m unable to provide guidance on setting the fall for the waste pipe, but a licensed plumber will be able to assess what you’ve done so far and make sure it’s correct.
