How do I replace the washer on this tap please?
Hello @Wendy54
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your shower mixer.
Please note that plumbing work needs to be completed by a licensed professional for safety and compliance.
Your shower mixer does not use rubber or synthetic washer. It uses a ceramic cartridge and taking your shower mixer apart and repairing it is part of regulated plumbing work and needs to be carried out by a licensed plumber.
Unfortunately, I’m unable to provide guidance on taking it apart and replacing the cartridge, but a licensed plumber will be able to assess the leak and find out what spare parts you'll need.
I just found out that you unscrew the grub screw with an Allen key. This takes off the handle. You then unscrew the dome inside gently. You then turn off the water supply. You then unscrew the ceramic spindle and take that part to Reece’s to get an exact copy. Put it all back together, turn water on and bingo! Problem fixed!
Glad you got it sorted @Wendy54.
Many thanks for the update.
