Wondering if anyone could provide some guidance on how to paint/resurface these kitchen cabinet doors?
Hello @Anthony068
Thank you for sharing your question about re-painting your kitchen cabinet doors. I suggest checking if your door is painted in a two-pack painting system or if it is a laminated surface. If it is a painted surface the general steps are to sand the painted door to provide a roughed-up surface for the paint to anchor onto. I then suggest using https://www.bunnings.com.au/dulux-1l-precision-white-maximum-strength-adhesion-primer_p1400848 to prime the surface and then your choice of topcoat in an enamel finish. A good example is https://www.bunnings.com.au/dulux-1l-vivid-white-low-gloss-aquanamel-enamel-paint_p1400966 tinted in your preferred colour. Please make sure to check the finish such as low sheen, semi-gloss and full gloss. Keep in mind as well that a roller finish vs a spray gun finish will vary as a spray paint finish will provide a more professional look.
However, if you have a laminated surface the general steps remain the same and that the surface will need to be sanded and roughed up to provide an anchor for the paint to hold onto. The difference is that the paint you need to use is the Dulux Renovation Range. You'll need the https://www.bunnings.com.au/dulux-1l-renovation-range-primer_p0116494 to prime the laminated surface and then the https://www.bunnings.com.au/dulux-2l-renovation-range-cabinet-doors-satin-white_p0116477 for the topcoat tinted in your preferred colour.
Harea are some handy guides that will help:
Please remember to wear personal protection such as gloves, goggles and a paint mask. If you have any other questions we can help with, please let us know.
