Hi There - I am seeking some advice on steps I need to take to replace insulation removed from my laundry wall. As you can see it is against the brick veneer so I am wondering if I need to put anything against the brick before insulating? What insulation do you recommend also?
Finally is insulation safe against the water pipes or should a separate insulation sleeve go over the pipes?
Thanks in advance
JC
