Hey everyone, looking for a bit of advice.
I’ve got some experience painting, but I’ve run into an issue I haven’t seen before. The house is 30+ years old. In the hallway entry, along the skirting board, the paint was flaking around the no more gaps. I removed the old no more gaps, scraped off all flaking paint, and lightly sanded the area.
Across the wall there were minor dents and imperfections from over time, so I filled those. Along the skirting board, where the flaking paint and old no more gaps were removed, I reapplied no more gaps. Where the paint had been scraped back, there were sections of brown plasterboard paper exposed, so I applied filler and 4-in-1 along the bottom and to any patched areas.
I then sanded all patched areas smooth and washed the wall with sugar soap. After that, I spot-primed the repaired areas with a 4-in-1 primer.
After everything dried, I cut in and rolled the wall, allowing proper drying time between coats. I’ve now done a 3-4 coats, but the finish is coming up patchy and streaky.
I’m not sure where I’ve gone wrong. But its driving me crazy.
Any advice would be really appreciated.
Thankyou in advance
