HI Team,
I have a large gap between floor, wall and tile floor where I pulled up old skirting board. It is deep, wide and runs the whole length of my laundry. The old skirting was sunk below the tile line.
My plan is to MDF the walls and install new cabinet and finish.
I see a few options.
1. Fill the gap now. If this is the right option, how? I'll be using dozens of tubes of silicone and days of effort on the caulking gun if this is the option. I read another of your solutions which suggested weather shield (https://www.bunnings.com.au/moroday-10mm-x-5m-white-gap-filler-rod_p4061881) first, then silicone. Still a lot of silicone.
2. MDF now and sink the sheets into the gap, then fill the gap, finish with skirting board over the top. Sounds easier except keeping the sheets up 5mm for the expansion gap at the bottom might be tricky. How would i do that? Also, I wasn't going to put skirting behind my new cabinets so there would still be a need to fill some gap.
If i put in westhershield, put the MDF on top, would that act as an expansion gap?
3. Something else?
Really appreciate advice. This was a little unexpected! I thought the skirting finished at tile level... not sunk below. Even getting it out was hard work.
