I am wanting advice on how to choose indoor security cameras that are wireless and are a network. That are able to record.
I would appreciate any advice or links.
Thanking you in advance
Welcome to the Bunnings Workshop community @DianeCrous. It's fabulous to have you join us and many thanks for your question on selecting security cameras.
You might like to start by reading through this helpful guide: How to choose a home security camera.
Also, check out these previous discussions:
If you’re choosing indoor security cameras, the main thing to focus on is finding a system that is truly wireless and easy to manage as a network. Most modern indoor cameras connect via Wi-Fi and are controlled through a single app, which is what allows multiple cameras to work together. It’s usually best to stick with one brand, like Eufy, Ring, or Swann, so everything connects smoothly and you’re not juggling different apps or compatibility issues.
Another important factor is how the cameras record footage. Some models offer local storage, such as a microSD card or base station, which means you don’t have to pay ongoing subscription fees. Others rely on cloud storage, which can be convenient for accessing footage remotely but may involve a monthly cost. For many people, a camera that offers both options provides the most flexibility.
Video quality and features also make a noticeable difference in everyday use. A minimum of 1080p resolution is recommended, but stepping up to 2K can give clearer detail, especially for identifying faces. Look for features like motion detection with phone alerts, night vision for low-light conditions, and two-way audio so you can communicate through the camera if needed. Some models also include pan-and-tilt functionality, which lets a single camera cover more of a room.
In practical terms, a good setup for most homes would be a small multi-camera kit from a single brand, as this gives you a proper network of cameras rather than standalone units. Systems from brands like Eufy or Swann are a solid place to start, especially if they include local recording and app control. This approach keeps things simple, scalable, and cost-effective over time. If you are looking for locally stored recordings, I'd recommend the https://www.bunnings.com.au/eufy-2c-security-camera-kit-2-pack_p0297033 .
Great to see you make your first Workshop post after being with us so long @DianeCrous. I'm sure this is a question of interest to many other members of the community, too.
I trust you found Mitch's advice helpful. Let me also tag helpful members @Nham, @R4addZ, @MikeTNZ and @Dave-1 to see if they could also add to the conversation.
Good Morning @DianeCrous
I've been researching/looking at security cameras for years… yes years lol Its a popular subject at the round table of coffee at work.
The main thing I have been waiting for is a camera that allows you to set storage locally. Not just on a SD card of the camera. But somewhere on your local network at home.
I dislike any that send it to the cloud for you to be able to look at but then the recordings have a time span of a week or two and they are overwritten unless you are paying a subscription. Plus you are uploading and downloading your own content which to me doesn't make sense.
I wander through Bunnings displays of cameras every few months to see what cameras do this. I cant name a brand but there was one the last time I looked (6 months ish back) Because the cameras are set up in store you can see the picture quality of each type. I am pretty sure it was mid range price to higher range.
The same brand and model of camera makes life easier. If you find one that looks ok Id be tempted to buy it and see. I almost did that with a el-cheapo model but when I re-read the fine print… cloud storage :/
Distance sharpness and how much shows up is something I also consider for outside security.
Hi @Dave-1 ,
You’ve raised a really good point there around local network storage. It’s something a lot of people are starting to look for to avoid those ongoing subscription costs.
There are a few systems now that use a base station or hub to store footage locally rather than relying purely on SD cards or cloud storage, so it’s definitely becoming more common. As you mentioned, sticking with the same brand across cameras also makes a big difference in keeping everything simple and running smoothly. I'd suggest the Swann security systems are likely what you're looking for. Systems like the https://www.bunnings.com.au/swann-1080p-full-hd-dvr-security-system-with-1tb-hdd_p0317069 have a hub which stores data. You can then choose to use their Premium service of cloud uploads if you need a back-up.
Thanks again for sharing your experience, it’s really helpful for anyone researching options. Mitchell
Hi @DianeCrous @Dave-1 @MitchellMc @Jason
Now I may be called biased because I am a registered cabler but no one requiring a "Security" system should be using WiFi for any part of the security network. You only have to look at the way things are now developing. Most people don't understand that Wifi is a shared network and many people around you may be using the same bandwidth, slowing yours down. but the latest development is a $40 device that renders WiFi security systems useless. See here
Burglars spent $40 on a WiFi jammer to disable security cameras and steal $25K from an LA family
By far and away the best solution is to use cabled "POE" cameras as they can't be interfered with. Also what most don't realise is that unless they are solar powered (which is unreliable at best) you still have to get power to them so why not Power Over Ethernet solving two issues with one solution.
The Hub or Base station referred to by MitchellMC is known as an NVR (Network Video Recorder) and many come capable of delivering POE to the cameras. Also note that you should also consider carefully where the NVR is installed as thieves have been known to steal the NVR to avoid being identified hence some people preferring cloud storage. It may be worth considering investigating an NVR that backs up to the cloud to get the best of both worlds.
Hi @R4addZ,
You make some really valid points, particularly around the reliability and security advantages of a hardwired POE system. Hardwired setups can definitely offer a more stable connection and remove some of the vulnerabilities that can come with wireless networks.
That said, WiFi systems still have a place depending on the application, especially where ease of installation, flexibility or retrofit solutions are key considerations. Like most things, it often comes down to the specific needs of the space and the level of security required.
We appreciate you sharing your insight and thanks again for adding your expertise to the discussion.
Hi @JacobZ
You say WiFi has a place but not as a security system! Would you buy a door lock that any thief with $40 could open? How does it make sense to buy something because it is easy to install or retrofit if it is so easy to circumvent? The story I linked to was the easiest to find but there was one recently reported in Australia so the trend has already hit our shores and anyone with WiFi based security is now vulnerable. Whilst I appreciate that Bunnings sell WiFi based cameras, it is now foolish to install them other than as a deterrent and you can get that from a dummy camera.
