I've got an old worn concrete slab in the backyard that's seen better days. Some sections are solid and others are crumbling away.
I'm (hopefully) planning on putting a floating deck on the rectangle section with dining table. And then crazy paving the square section and putting a bbq entertainment like area there so both areas will need to hold a bit of weight.
My question is with the state of the current concrete slab is it fine as is and doable with the above? Or is there a way I can touch it up? Or should I demo it and put a brand new concrete slab?
Thanks
