Some of you may remember helping me take the warp out of the slab I previously used for this bar. Well mango wood is a soft wood and ended being a poor choice for outside. So time to change it for a hardwood - I chose melaleuca.
Sandpaper
Lindseed Oil
Tape measure
Ruler
Pencil
Baton screws 14g x 70mm (depending on the slab)
Circular saw
Belt sander
Detail sander
Router (optional)
Drill and driver
- Measure and cut the shelf and cut the slab so it's square to the eye.
- Use a belt sander with 80 grit sandpaper to get the slab smoothish
- Detail sander with 150 grit to get a smooth finish
- Rout the edges if you want a rounded finish. I didn't do this.
- Use linseed oil made for outdoor use as directed. 2 coats recommended but I did 3.
- Pre-drill the holes
- Screw the top and shelf in place.
- Grab a coffee
