I made a repair on some concrete steps. Filling in a cut out corner. Mostly went well. I then used turbo concrete bog to fill a bit of the crack between the old and new concrete so that things would look seamless after painting. About 2 months down the road the constant heat from the sun has caused it to bubble and start flaking off wherever the bog was. I want to grind it back repair it then repaint it. Is there a better product I can use to fill the cracks/join which will be durable enough and also not start swelling with heat exposure?
