Hi there,
I've re done my bathroom subfloor and installed James Hardie Secura fibercement sheets (22mm) (following all manufactures indications) Now I need to continue installing screed and tiles.
I have limitation on the height, so I want to minimise the screed thickness, hence trying to go with a bonded screed.
However, I noted that Ardex only recommend un-bonded screed for FC. Do you know of other manufactures who recommend bonded screed? (and which prod are compatible with JH Secura?). If none, how risky would it be to go ahead witha bonded one?
The bath dimension is 1.8x1.8 mm, not a huge area and the subfloor and joist are quite solid so i expect minimal movement (if any) of the sheets)
Thanks,
Martin
