Hi Team,
I would like to build a tv cabinet similar to the one in the link above. Could you share the process and the link to the materials?
Welcome to the Bunnings Workshop community @Minea. It's amazing to have you join us and many thanks for your question on building a wall cabinet.
That style of cabinet looks great, but it’s worth saying upfront that what you’re looking at is quite an advanced build. A long, floating, wall-mounted cabinet like that is usually custom-made by a cabinet maker and securely fixed into the wall framing. It’s not a simple weekend project, especially if you’re working with standard off-the-shelf materials.
Before getting into how to approach it, it would really help to know a few things. What type of wall are you fixing it to, for example, plasterboard on timber studs, brick, or concrete? What tools do you have available? And how confident are you with DIY projects like cabinetry or wall fixing? Those factors will determine what is realistically achievable.
The reason many people go for pre-built TV units is because even getting a floating cabinet safely mounted is a project in itself. These units need strong internal framing or brackets, and they must be fixed directly into studs or masonry with the right hardware to safely support the weight of the cabinet plus anything stored inside. If not done correctly, there is a real risk of it pulling away from the wall.
If you’re keen to achieve a similar look, a more approachable option would be to use pre-made cabinets or modular units and then mount or frame around them. For example, you could install a couple of low wall cabinets and then build a simple face panel or backing to give it that seamless, floating appearance. This reduces the complexity while still getting close to the design you like.
If you can share a bit more about your wall type and experience level, I can suggest a more tailored approach, including materials and steps. Realistically, though, by the time you purchased timber framing, panels, fixings, and hardware, including drawer runners and mounting items, you would be a good way towards the price of something like the https://www.bunnings.com.au/2-4m-majeston-white-floating-tv-cabinet_p0975507 . You would also need a high level of cabinetry-making skill to achieve anything close to the finish on a pre-built unit. You might like to check our this previous discussion: Ideas to get a wall unit like this by @Itai. Also, @JoeAzza put together this wonderful Floating entertainment unit to hide internet cables.
